Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: Apr recirculation valve or Forge splitter BOV?
    Sep 2008
    Hi guys, just wondering if anyone could enlighten me on the pros and cons of each and which would be the most preferred choice between the two? Any suggestions, experiences etc would be much appreciated.
    Jan 2008
    Cremorne, Melbourne
    i have the Turbosmart Kompact Series Dual Port BOV and i have had it on for about 7-8 months now. It did throw a DV code (diverter valve) on VAG COM at the last dyno day but nothing sinister has happened to the car yet...touch wood
    the dual port (splitter) will send half the air back into the intake system (which is needed for our MAF sensor) and half out into the atmosphere, making the pssshhhhh noise. it has been said that this increases turbo lag but i am yet to experience this. you do run the risk of putting your car into limp mode cos of the lack of air being recirculated. this can be sorted by just turning the knob on top of the BOV to a harder setting.
    full plumbback....well....it will keep your MAF sensor happy but you just won't get the "pssshhhhh" noise of the dual port.
    whatever you do, don't buy a full atmosphere BOV, our cars do not accept them.....your car will definitely go into limp mode.
    if i was to choose again i would go for a full plumbback BOV. the beauty of mine is that i have a screw-in plug to make it a full plumbback if anything bad happens.
    Kai had the same as mine and had his car "shut down" (everything shut off - electrics, engine, lights) on the HWY. he just put the clutch it, turned it off, then back on again and it was fine
    Blitzen (Ryan) has the Forge Dual Port, he'll be able to fill you in on that one.
    2010 Reflex Silver MK6 Golf GTI
    Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
    Feb 2008
    I have fitted the Forge Dual Port BOV to my car, and have not had any dramas concerning Limp Mode or poor performance.
    The Forge BOV (FMDSPLTR) is designed so that 70% of the air goes back to the intake, and 30% to atmosphere. This will not affect the ECU.
    I know that Dave Mack has a APR R1 Diverter Valve, so talking to him may help.
    Mar 2007
    sydney
    i have a apr r1 its the bomb very quick response,
    mk4 the mods begin for round 2 hahahha
    Sep 2008
    Thanks for your opinions Blitzen and Polo Gti...Just also wanted to know if any particular one would be better performance wise and which one would provide an overall benefit to the car?
    I've always wanted a turbo charged vehicle so I could fit a BOV in it and from my understanding there's no 'psssshhh' sound with the APR one but there is with the Forge splitter one. So would I be correct in assuming that the FOrge splitter one would not cause any limp mode or MAF sensor problems? Also, since the Forge one does comes with a blanking plate which allows it to be converted to a full plumback one, would it be better for me to buy the Forge one rather than the APR one since I can change it from sound to no sound configurations?
    Cheers.
    Aug 2006
    have u's ran a full atmo BOV before?? coz alot of people who are not on these forums do.. mite run rich, but on d dyno.. no major problems
    Jun 2008
    New Caledonia
    Quote Originally Posted by Gti Dave View Post
    Cheers.
    I'm not against you but it seems you don't know that you can use the research function on the forum either you are a little bit lazy...
    Anyway :
    http://www.vwwatercooled.org.au/newf...&highlight=BOV
    May 2007
    I have a GFB BOV. It lets me turn itself from 100% atmo to 100% plumb from inside the car. I've never run into any problems with 100% atmo, but i'm kind of over it now and run it plumb back nearly all the time.
    No idea why mine works fine on atmo, no limp mode. It does make the gear changes a little more choppy i think, but tahts about all i noticed.
    Dec 2006
    Gold Coast
    Quote Originally Posted by BL33SU View Post
    I ran it at full atmo for a while. Worked great. Then randomly one day it started dieing.
    You can also run the car without the maf sensor. Just unplug it and the esp light comes on. I did this for abit too (with maf removed).. No idea if it was doing any damage. Car ran perfectly normal. But didnt stall with the bov fully atmo.
    Feb 2008
    I ran the Forge BOV at full atmo(it has this ability), but my car went into limp mode about 200m up the road.
