Im just curious for anyone that has the APR reflash what program is stock and what program is flashed? ie blink one (program one) blink two (program two).
Current - MY12 MK6 GTI, CW, Detriots, dark tint, APR Stage 1, blacked out grille, LED tails, Euro plates, suspension "tweaked", VCDS tweaks
"The Ex" Black MY08 POLO GTI - APR,Coilovers,5% tint,stubby antenna, rear sway bar
pretty sure the double flash is the APR power setting.
GTI. Leather.
tint,Eibach pro-kit,Whiteline adjustable swaybars,Forge s/brace,BMC,Forge T.I.P & D.V, Cupra R, APR. EBC & 3''dump pipe
Koz,
See : http://www.vwwatercooled.org.au/newf...ad.php?t=13358
Give us a call - we can look it up for you in which order its been installed!
spot on mitch. single flash is standard setting and double flash is race-gas setting (chipped). you then need to turn your car completely off for 10 seconds before firing up.
in saying this however, it can be installed the other way around. i'm sure if you have a fiddle around for a couple of minutes, you will know the difference!![]()
2010 Reflex Silver MK6 Golf GTI
Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
Thanks guys. My chipped mode is Program two.
My car is definately playing up, it hasnt go the normal kick it used to have. Im missing a fair amount of power. I will check for any boost leaks etc.
Mate, either you're getting used to it (....it happens....) or could also be a bad batch of petrol.
I've noticed (since I added a boost gauge) that different fuels actually vary the max amount of boost (3rd gear) I'm getting.
Not wanting to start with an old thread again, but BP Ulitmate holds at 1.3 bar, V-Power at 1.4 bar and V-Power racing at 1.5bar. Never would have guessed untill I happended to switch due to necessity and saw a drop in boost. Not any real drop in noticable power though.
Well I know its missing a beat and im not getting used to it.
I thought it was petrol because i normally put in BP Ultimate but couldnt find any stations that had any type of 98 RON so I had to put in $15 of Mobil 95 RON, then I filled up with Caltex Vortex 98 and it was still running **** then I just filled up with BP Ultimate 100kms ago and its still running poor.
I thought if it was the petrol then it would be coming good by now.
This is actually wrong Rhys. Race-Gas would be a 3rd or 4th program (for extra cost). Make sure you got 100 (it might even be 104?) octane if you do have the race gas. It's for 100 octane fuel. And yeah, it's not always 1 for stock 2 for 98 RON. That's the norm but they can do it in any order.
