Standard internals are good for up to 300kw from all reports... which is far more than you'll get with the stage III+
Edit: That said, I think you could end up with more peak power, less lag, and more ability to further upgrade later by going to a good tuner and doing a custom build with an aftermarket ECU. Stage III+ ain't exactly cheap, and the cost of manifold fabrication, doing a fuel system upgrade, cost of a new turbo, cost of ECU, then cost of fitting and tuning would likely be similar in the long run.
Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
Current Ride: Evo 8 MR, Fabia MK3
