Page 7 of 7 FirstFirst ... 567
Results 61 to 65 of 65
Thread: Anyone fitted their own coilovers and had to use the M14 driver???
  1. #61
    Sep 2011
    Hey buddy, yeah you'll need it. Don't go buying one though. Just give me a call and you can borrow my set.
  2. #62
    Apr 2011
    You can get the stock struts out without spring compressors but the length of the strut means you may have to disconnect tie rods etc to get the hub to drop away far enough. Obviously the coil over makes it much easier as you can shorten the length of the strut right down and just pop it in/pull it out.
  3. #63
    Good to know. I was hoping that would be the case.
    See how I get on...
    Polo GTI MY2008
    Build Thread
    136.09kW and 305.28Nm torques, Dynapack Hub Dyno
  4. #64
    I ended up borrowing the bits off Lukas, cheers mate.
    Just thought I'd add that a 3/8" ratchet head fits in the M14 bolt perfectly as well
    I had to adjust it this afternoon and didn't have the bit on me...
    Polo GTI MY2008
    Build Thread
  5. #65
    Sep 2011
    Glad to help out, Sam!
