Hey buddy, yeah you'll need it. Don't go buying one though. Just give me a call and you can borrow my set.
You can get the stock struts out without spring compressors but the length of the strut means you may have to disconnect tie rods etc to get the hub to drop away far enough. Obviously the coil over makes it much easier as you can shorten the length of the strut right down and just pop it in/pull it out.
Good to know. I was hoping that would be the case.
See how I get on...
Polo GT
I MY2008
Build Thread
136.09kW and 305.28Nm torques, Dynapack Hub Dyno
I ended up borrowing the bits off Lukas, cheers mate.
Just thought I'd add that a 3/8" ratchet head fits in the M14 bolt perfectly as well ![Wink](https://www.vwwatercooled.com.au/forums/images/smilies/icon_wink.gif)
I had to adjust it this afternoon and didn't have the bit on me...
Polo GT
I MY2008
Build Thread
- You may not post replies
- You may not edit your posts
Forum Rules
