Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Annoying rattle part2
  1. #21
    Jan 2009
    Quote Originally Posted by GTI_PAPA View Post
    Am very hesitant to take it back to dealer. As you may have read, I have had nothing but grief from dealer. Every time it goes in, something gets damaged or things aren't put back together properly. Enough reason to see if I can sort it myself...
    Any thoughts as to a penetrating spray/adjustment etc that might permanently sort this problem peoples?
    Cheers.
    WD40 perhaps though Jimmy had used some stop-squack on my door hinges, worked an absolute treat.
  2. #22
    Jan 2009
    blankedy
    I thought a dry lubricant for doors, etc?
    Sounds like you are getting there mate, good luck.
  3. #23
    Essendon
    Agreed. Graphite powder FTW!! Stopped many creaks/rattles around my doors.
    Sunroof // ICT Tint // Seats // Steering wheel
  4. #24
    Aug 2007
    HHS Creep oil guys, it wicks into the joint and hinges and is the cats pygamas.
    Ill take a pick of the can tomorrow when im back at it, yes a Sunday!!! Im off for Easter so got lots to get through, to top that my Thinkpad screen went south today ARGGGGHHHH!!!. Ah well i know stuff breaks, i spend most of my time fixing broken stuff hehehe
    All good
    Jmac
    Alba European
  5. #25
    Feb 2010
    Quote Originally Posted by Jmac View Post
    This may sound silly but ive seen it on a couple of polos. Check the T30 Torx bolts on the front panel. Seriously the bolts above the headlamps. They come loose and resonate.
    Remove it and put a blob of medium loctitie on the bolt and screw it back in tight. Like i say seen a couple now and sounds like inside the door. It transfers from the front panel back.
    Try it
    Jmac
    I had this annoying rattle and it was driving me nuts!! I opened the bonnet and tightened the bolts that Jmac was talking about. I cannot believe that it fixed the probelm just wanted to say thanks as I was going crazy!!
    Now this is some annoying rattle in the dash I need taking care of!!
    Oct 2009
    new south wales
    Hey guys,
    Thought I'd update you re: door rattle. As I have mentioned before, I traced the rattle to the lower door hinge. After fudging around with remedies (penetrating sprays, oils, grease, dry lube etc, etc...), I decided to try a physical fix. Went to clark rubber, purchased a strip of 16x16mm high density foam rubber, cut it to size and stuck in in the door jam near the lower hinge (theory behind this is to have it place outward pressure on the lower hinge to prevent excess movement), and hey presto, noise gone!
    Have been driving all afternoon with a smile from ear to ear, and sanity slowly returning. After 3 visits to the dealer, dodgy repair work, door trim damage etc, a simple piece of foam sorted it...
  7. #27
    Jul 2007
    Auckland, NZ
    and my interior centre console rattle...? dealer had it 3 times, they did try - putting foams and felt liners everywhere... no fix. Worse in colder weather as well. My partner knows that I go mental with rattles. She had 2 name cards that she had in her purse -> stuck them into where plastic meet. Just 2 places. The noises complete gone. Only rattle now in interior (most of the time) is my New South boost gauge.... they refused to replace it.
    06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
    06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
  8. #28
    May 2009
    Kuala Lumpur, Malaysia
    Try it
    Jmac
    my polo was involved in a little collision last month, nothing dramatic, but i did have to change my front bumper. needless to say, after the collision, a rattle has developed on the passenger side. i swear the rattle sounded like it's coming from the door panel or dashboard.
    well, last night i tried to find the source of the rattle. two hours later without any luck, then i remembered jmac's post.
    the said T30 torx bolt just above the passenger side headlight was loose. tightened the bolts (both sides for good measure) and voila, the rattle is gone.
    thanks jmac! you just saved me a trip to the dealer.
