mine are electric. oil temp is picked up from a small sender that is screw into the top of the oil filter housing
What have you lot done for extra gauges, and where have you put them?
I'm thinking boost and oil temp; but unsure where to place the sender for the oil temp takeoff.
Do you have electric or mechanical ones?
Looking into stack gauges atm, but open to suggestions.
Any help greatly appreciated
Cheap, Fast, Reliable. Choose two.
APR V2 | APR Downpipe + custom catback | APR solid mount | FMIC | SEAT intake | BMC filter | FORGE 007DV | KW v1 | WHITELINE RSB
139Kw | 271.8Nm atw - At a new home
I went for a Saber electronic item mounted on my steering column.
I wrote up a guide on how to fit a gauge here: Click Me
Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
Current Ride: Evo 8 MR, Fabia MK3
I'd be interested to know too - I know a VDO oil PRESSURE (not temp) sender screws right onto the oil filter mount but not sure if there's enough room for it, it being that close to the radiator.
Changed the LED to a red one since, now everything on the centre console including the head unit light up red.
i hav defi turbo, oil temp and pressure.
using after market adaptor from ebay, with shorter oil filter.
pics: http://cid-381026bd24bf5290.skydrive...96%b0%e6%ad%a1
on the top of the oil filter housing is a little 4-5mm allen screw which i removed and replaced with the mini sender that i had to buy seperate from the temp gauge. i bought all my gear from 42draftdesign, i think it was this sender [http://www.42draftdesigns.com/catego...o/vc323423.htm]
they have how to on their site and i just followed the instruction from there. put a bit from thread tape, clean it up, run the wire into the car via the passenger door. works great esp when i went to the track.
2013 4Motion "BLACK BEAR"
http://blackbeartiguan.blogspot.hk//
