Unless the blower has electronic speed control it sounds like the blower resistor pack has failed. The fan speed switch selects different resistors in series with the blower motor to change the speed. At max speed the resistors are switched out of the circuit so that is how it is possible to have max speed but none of the others.
The resistor packs can have to dissipate significant heat so they are normally fitted in the airstream just after the blower to cool them. I think the resistor pack also has a thermal link for protection. So it is probable either the thermal link or the resistor for speed 3 has failed (as it is also in the circuit for speeds 1 and 2).
