Yes, you can see it in my pic. I'll be ditching it once the SAI is bypassed.
eBay will have lots of options, don't want to be sucking crap in
its the bottom section of a plastic tray. I went to Bunnings and found something designed for outdoor use (more durable), under $10 and something big enough I could cut a section from.
As there is not much force (mild vacuum) in the box, it does not need to be bulletproof, just strong and durable.
Still rocking this solution, works well, cheap and serviceable with the front brace. For anyone reading this and thinking about something similar, this is to be used in combination with the PD160 Seat intake section, removed front flap in the mouth. These make more of a difference than the filter / config of the airbox.
Great thanks for that![]()
