Page 8 of 11 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 102
Thread: Air Intakes
  1. #71
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by instigator View Post
    they use carbon because its lighter, and it conducts heat better as plastic or metal.
    so you get optimal cold air flow.
    Since it's sitting in the engine bay, won't it actually add more heat to the intake air, rather than less??
  2. #72
    Jul 2010
    Quote Originally Posted by vwthunder View Post
    I am in the process of putting in a smaller battery, custom battery tray and a BMC CDA
    Should have it all done soon hopefully, still waiting for a few things
    Kind of wanted to do it to clean up the engine bay
    Look forward to seeing it and hearing whaty ou think of it compared to standard setup. You and Gti Dave are pioneers.
    MY2008 VW Polo GTi / GIAC Tune / Forge FMIC / Forge 007 DV / N75 Race / BMC OTA / KW V1 Coilovers / Whiteline Front&Rear Swaybars + Toe-In Shim / Weichers Front&Rear Strut Braces / Full Non-Res Milltek Exhaust / 17" Bora Sport
  3. #73
    Jan 2009
    blankedy
    Quote Originally Posted by kaanage View Post
    Like the stock airbox? Hard to get around, atleast if you plumb it correctly it's pulling cold air in
  4. #74
    Aug 2007
    Ive been pro stock for moons, and against k and N and the likes due to poor filtration, yea the induction is better but filtration not so. Enclosure which has been mentioned here is paramount otherwise why have a filter at all?? What you want is an intake set up with cool stuff coming in, yes cones are good but not deep in the engine bay as you will draw in too much heat. The stock filter box in most cars are well set up for what they are but are also set up for noise reduction, so you can have a good hack at it with some results. Set up your intake so you get as much cool stuff in as you can and have some good filtration. Half assed jobs are no good with little or no benefits and the story goes you get what you pay for.
    Jmac
    Alba European
  5. #75
    Sep 2006
    Quote Originally Posted by Jmac View Post
    Jmac
    Stock one is so boring lol, and takes up too much room in the engine bay, need room for a catch can too
  6. #76
    Point Cook, Vic
    Im a fan of stock airboxes and many cars have made good power with slight modifications to them but compared with a mk4 gti or a3t airbox the polo one seems to be more an answer to a packaging solution than to a performance one. The surface area of the panel filter seems quite small compared to other cars.
    FOLLOW US ON FACEBOOK
  7. #77
    Dec 2010
    jhb, south africa
    Seems that they made things really hard when it comes to this aspect of what is a fantastic engine. Locally a few mates have opted to go with the cone and a 90' bend inside the stock box which sucks up heat on a dyno but the improvement is definitely found on the road. This costs in the region of aus $35 so its definitely worth the try
  8. #78
    Dec 2010
    Dalton, New South Wales, Australia
    Aren't the pleats quite deep?
  9. #79
    Jul 2009
    Can anyone tell me if the Seat intake increases intake noise at all? I would like a bit more intake noise without being too obvious.
  10. #80
    Jan 2009
    blankedy
    Yes, but I'm not sure if it would without chipping it first...
