Page 7 of 11 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 102
Thread: Air Intakes
  1. #61
    Sep 2006
    I am in the process of putting in a smaller battery, custom battery tray and a BMC CDA
    Should have it all done soon hopefully, still waiting for a few things
    Kind of wanted to do it to clean up the engine bay
  2. #62
    Dec 2010
    Dalton, New South Wales, Australia
    What is a "BMC CDA"?
  3. #63
    Nov 2010
    2016 MY17 Polo GTI with DA package. TMD fitted + Weather strip and Snow Screen removed otherwise dead standard.
  4. #64
    Dec 2010
    I wonder if it has less than 1 inch of water pressure drop? After much testing (but I must say, not all on VW intakes), I prefer to stick with the factory airbox and filter - and replace much of the other bits!
  5. #65
    Sep 2006
    Quote Originally Posted by Julian Edgar View Post
    BMC filters is what they use on some of the finest cars in the world and also Formula 1
  6. #66
    melbourne
    yeah... and you'd be right- check out tdiclub.com... those boys swear time and time again that anything other than the stock air intake setup, is sacrificial......
    stick with what you've got, unless you go with a "dry paper filter media conical air intake" like greg roles etc on here... anything else will be a warm air intake...
    sheesh, i feel ***king stupid for running my BMC oiled filter in my polo tdi (same engine)... im gonna replace it with the stocky soon...
    p.s. no offense whatsoever to the petrol boys... when you delve into the rabbit hole, same size engines have very different characteristics when it comes to diesels.... (e.g. dump pipe = good, on petrol 1.8T vs. dump pipe = blow turbo sooner, on 1.9 TDI)
    cheers,
    scotty
  7. #67
    Sep 2008
    Quote Originally Posted by vwthunder View Post
    Agreed, hence I've always gone with BMC and ended up selling them too. He He He
  8. #68
    Jan 2009
    sunshine coast
    bmc = air filter company, cda = cold air intake, should be a few threads floating around about using the search option if your curious
    " I wait I resolution derive pleasure this " latest spammer post
  9. #69
    Oct 2009
    syd
    I don't know if the Seat intakes are still available through dubbadiction, otherwise GTI Dave used to arrange group buys.
    Alternative is pod filter setup, technically illegal in NSW i think.
    As long as its a dry filter and its got an enclosure, you'll be fine.
  10. #70
    Aug 2009
    Belgium
    BMC is the company wich makes them.
    CDA is Carbon Dynamic Airbox.
    it's a Carbon cilinder shape box, wich houses the airfilter.
    they use carbon because its lighter, and it conducts heat better as plastic or metal.
    so you get optimal cold air flow.
    verry good system, but it has a good price to...
