Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 102
Thread: Air Intakes
  1. #21
    Mar 2007
    Gold Coast
    Quote Originally Posted by break View Post
    You could just buy a K&N Apollo kit and run the feed to the factory location for the same result with a far reduced cost.
    Any pics of these in a polo bay?
  2. #22
    Nov 2008
    The air will get in, its just not going to get any ram-air type assistance like I think it could / should.
    Can you really generate a ram air effect travelling around on "normal" roads ?
    I was under the impression you needed to be doing a very fast speed - ram air works for jet engines - it is the same with most aero kits ... they look good but you aren't going to get any noticeable benefit driving at 110km/h on a freeway.
    Hoping someone who's played with this stuff has some definitive answers and not more speculation as I'm skeptical about any benefit trying to "ram" air into the inlet ... you may get a benefit from colder air (not drawn from engine bay) but I just doubt you have the speed to generate an air mass great enough to create a ram effect.
  3. #23
    Jan 2009
    blankedy
    Quote Originally Posted by DeanB View Post
    To get definative answers, we would have to do it and measure the before and after. If the standard intake system from the front of the engine to the MAF is not restrictive (lets assume with the Seat 160) then whats the point? Well, with a better designed inlet, we may be able to force air into the system, reducing the work on the turbo.
    Will it work? Depends on how well designed and engineered the solution is (or some luck!)
    If you have not read the Intake restrictions thread, it has some ACTUAL DATA!!! Thanks to Awestonvp for his contributions.
  4. #24
    Jan 2009
    For more research that has been done, check out Autospeed.com, or try this link - http://autospeed.com/cms/search/inde...rds=ram+intake
    From some of the DIY's I've read, it is quite possible and cheap for tests to be conducted on our vehicles. It'd be a matter of getting the testing gear and a few cars together. I don't have the time to read it at the moment to give a quick summary.
    EDIT - this is what I was thinking, http://autospeed.com/cms/A_1023/article.html
  5. #25
    Jan 2010
    FML i missed it by 3 days
  6. #26
    Mar 2010
    Sunshine Coast, Qld
    What a shame
    I got one of those SEAT intakes a while back - works like a charm & easy to install...recommend
    Shame they are harder to get hold of now...
  7. #27
    Jan 2009
    blankedy
    I noted Tim @ Dubbaddiction is getting a batch of the Seat intakes. PM him if you missed out on this to secure one through him.
    Link here
  8. #28
    Nov 2010
    anyone know of how to get hold of the SEAT intake now?
    Jun 2009
    Quote Originally Posted by sssstew View Post
    SEAT PD160 Intake Trumpet and Intake Pipe - $189.00 : Dub Ad·dic·tion [duhb uh-dik-shuhn]
  10. #30
    Nov 2008
    Get one from Tim at Dub Addiction :
