The thinner VTDA modshack or similar thin fully enclosed cannister filter, and use 50mm silicon fittings and 50mm alloy pipe off e-bay. Just make sure you seal it to the outside air, as even the smallest gap near the inlet vent allows hot air ingress, sealing the front of mine made a noticable response difference. Is the MAF in this section?
