Results 1 to 10 of 19
Thread: Air conditioning does not work well in polo 9n 2005
    My one is 2005 model.
    (I do not know how to fix the title)
    The air condition was working good when the weather outside is okay. But if the weather is so hot, then it cannot work efficient.
    I just purchased this used car from dealer a few days ago. Im not sure that is normal problem or not? How much will it cost if I want to fix it?
    I find out that a lot of people said BMS darlinghurst is good. Are they good in fixing air condition?
    Jul 2010
    Robina Gold Coast
    If it's a 2015 model it's under Warranty. Take it to a VW dealer.
    Sorry, It is 2005. wrong typed words. Does anyone know how to fix the title?
    Air condition does not work well in polo 9n 20015
    Quote Originally Posted by ian View Post
    It is 2005. Out of warranty. Just 60000 km
    Pacific Paradise QLD
    Quote Originally Posted by miaqqi View Post
    Go to edit / Go advanced should be able to do it
    Jul 2007
    Brissy
    I fixed the title for you.
    Seriously speak with the dealer, you probably have some statutory warranty, differs by state. Dunno where you are located.
    If you don't get a good response then call your state motoring club, RACQ / RACV etc, to get some proper advice.
    AC is not cheap.
    The fan should be on whenever the ac is operating, if not temps will rise and the pressure switch will deactivate the compressor, or the compressor may **** itself (or already has).
    A new fan might only cost $100.
    Next would the the compressor, maybe it is dying.
    A compressor is anywhere from $350 and up (VW will quote like $700-$900),
    Regas costs about $200 depending on how much gas is needed to top up.
    Labour to replace the compressor would be $300-500.
    So you could be looking at a $1000+ easily, or around $600 if you DIY (still need the regas)
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Quote Originally Posted by JustCruisn View Post
    AC is not cheap.
    Wow!!! Sounds so scary!
    I live in Sydney NSW
    According to NSW rule from website, the car is older than 10years, so dealer has no responsibility to give me warranty. Also ask me to sign it.
    They give me 3 years warranty which is including ac parts (compressor, evaporator and condensor, no regas) $1000 Grand. No limit to the number of claims
    I can return the car but refund will deduct $1000. I do love this car which is so cute!
    I know a cheaper mechanic guy to help me fix my Toyota compressor before, just cost me 350 in total. Im wondering should I find out a mechanic guy who is major in european car? Looks like they are more expensive.
    AC is not cheap.
    PS for last message from me, thanks for fixing my title.
    Jan 2009
    It could be any number of things with the description provided. The "heater/cooler" switch has been known to play silly buggers. By that I mean, my air con is cold but when I change the temp setting it can turn off the air con. I can turn the AC on and Off a few times and it's all working fine again - so I don't change the temp anymore and it's no problem It's not the button on the dash, but a solenoid elsewhere in the system.
    The good thing is that you can run a scan on the car and tell you if that's the case and diagnose a few things that way. A mechanic should be able to scan your car. If a scan shows nothing, it's more likely to be a mechanical fault than electrical.
    If you have the warranty, it may all be sweet, go back through that. They should diagnose for free, if they try hit you for the cost you can make a judgment call or escalate through warranty. My wife's car had an air con issue which was all sorted under the used car extended warranty, that was a $1500 "as factory" warranty. Money well spent so far.
    Daily: 2010 VW Jetta Highline
    I check with the warranty company-National Warranty Company. They refer me to see their authorised mechanic which is not european specialist. Is that okay?
    What is the different between european specialist and non-euro specialist?
