Results 1 to 10 of 18
Thread: air con system delete
    nsw
    I'm going to go ahead and remove all the air con gear in the car. It hasn't been re gassed in 4 years and I don't intend on doing it either. Its all just dead weight mostly on the heaviest corner of the car so its coming out. I've looked around on the web but I can't seem to find shorter A/C delete ancillaries belts. Does anyone who has done this know if there are shorter belts that are available and if that's all I really have to worry about with this mod?
    thanks
    sam
    Quote Originally Posted by sambb View Post
    thanks
    sam
    Measure around the pulleys and miss out the AC and then look on line for a belt of the appropriate length.
    Jan 2009
    Is that just a matter of removing the compressor and sorting a shorter belt? Leaving the radiator and pipes in?
    Daily: 2010 VW Jetta Highline
    Jul 2012
    Sinagra, Western Australia
    Not if you wanna do it properly, if all you are doing is pulling the few pipes out and a compressor you may as well leave it in. Condensor and evap need to be taken out also, one of which is a dash out job.
    Volks Handy
    Servicing - Repairs - Diagnostics - Mobile fault scanning/clearing - A/c work
    10 years experience working for Audi/VW/Skoda
    Now in Perth NOR, Western Australia.
    nsw
    I was mainly hoping to remove the compressor and the condenser (that's the AC radiator in front of the radiator isn't it) - just the heavy stuff at the front of the car. There must be 20+kg of dead weight there out over the front wheels that I have no use for + I assume I'd get better airflow through the radiator with the codensor removed. If possible the pipe work can stay in so that I can reinstall it down the track before/if ever I sell it. Beside the radiator there are some AC hard pipes that use compression fittings held in by circlips that if I separate might allow me to remove the condenser neatly. That's what I was hoping for anyway.
    Jul 2012
    Not worth the hassle mate, compressor is at most 5kg; condensor maybe another 2kg?
    Go for a jog and take a decent dump before you go track, same same.
    Volks Handy
    nsw
    only 5kg for the compressor yeah? I thought it'd be heavier than that. The compressor has a clutch system or is it always a draw on the crank?
    Sep 2006
    I have removed the compressor and condenser and piping from my engine bay, dont want it on my new engine, it looks horrid
    I will be searching for a new belt also. Was told to do what gav said, measure and go to supercheap or somewhere and look for the right length ribbed belt
    MODS- TOO MANY
    nsw
    Got a weight figure from what you removed? Yeah i'll source the belt at least so I have it. I'd thought that maybe there were 1.8T's in something that had no air con and that there might be an off the shelf VAG belt but if I can find one at repco/supercheap etc then even better.
    Sep 2006
    Hmm I put all the parts off into storage where i never go, didnt weight them
    Im guessing the compressor is about 10kg (quite heavy) , condenser would be another 3kg, lines another 1kg
    MODS- TOO MANY
