After driving around for nearly 3 hours today, I have decided I need to replace my air con; it's bloody useless.
Before you suggest getting it looked at, I have. No one can find any fault with it, but almost every one agrees it's crap. My question is, are there aftermarket units available. If so, where should I start my search?
Sunroof // ICT Tint // Seats // Steering wheel
Black|APR Tuned|APR Dogbone|SEAT Intake|BMC Airfilter|Forge TIP|SEATSports Front Strutbrace|Forge Rear Strutbrace|Whiteline RSB|Bilstein B8 & H&R Springs
can't believe this hasn't really been covered before...i agree, the air con is crap...not that cold & the vents don't angle down enough!
will keep an eye on this thread for sure
i dont even use my air con. but the few times i have its been not steller but adequate.
" I wait I resolution derive pleasure this " latest spammer post
Use my air con every day and to be honest I've found it to be quite good. Not as good as the astra I came out of (you could store meat in that car at the lowest setting), but still very good.
Doesn't hurt that I am parked underground both at home and work, so the a/c only really has to maintain car temperature rather than try and cool it. If I am parking in the sun for a decent amount of time I usually crack the windows an inch as well to help keep the temperature down and give the a/c less to do when I get back in.
Pixl, is there a particular occassion that the a/c is worse than others? e.g. mine on the highway is great, but notice an obvious drop in cool air when speed decreases and no flow. This is not uncommon, more common in older, small capacity engined cars, but may be overcome with a better A/C radiator perhaps... I have very limited experience in air cons, but the principle is quite simple in being a heat exchange. Might be worth the question of specialists.
I agree, the air con is awful. It's a big joke with my mates but I have stalled a couple of times with the AC on.
aus liebe zum automobil
Strangely I've never had an issue, works fine whether around town or on a hot day.
You sure it isn't worth getting independently checked ie gas pressure, etc ? The Mrs Pug was never cooling very well, dealer gave it the okay on 2 occasions before I took it up to the local auto air-con guy who found that it didn't have enough gas in the system !! Now it is like a mini fridge, nice and cool on the hottest days![]()
I think the Air con sucks.
On the flipside easily the best heater any of my cars have ever had (not much good in Brisbane unfortunately)
It is just cold enough. It has a horrible impact on driving and increases fuel consumption by about 30%. Its robs power before its finds the boost makes it laggy- yes I also stall it when I forget that it is on (it needs a tiny touch more accelerator).
I would like to set it up so that it has an eco option, like some Toyotas have, the kind where it only works on zero throttle or when the car reaches 20km/hr. It runs the compressor when you are going or slowing down - like a regenerative brake. Probably would not help with making the cold but at least it would drive a lot better on hot days.
try regassing it?
on one of my previous cars the air was piss weak, ended up getting it regassed and the a/c was colder than any other car a/c ive ever felt.
