Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 71
Thread: After the Flash Tune - Add a Dump pipe
  1. #21
    Dec 2006
    Gold Coast
    He already makes the dump + cat for the polo but that only comes in a full exhaust.
    If you can sell that seperatly. That would be awesome.
    If you need to do tests and shiz my car is always avaliable
  2. #22
    Jun 2007
    Brunswick, Victoria
    Would a dump pipe from the turbo to cat make much difference in regards to the sound if at all?
  3. #23
    Nov 2006
    Quote Originally Posted by Koz View Post
    In my case, virtually no sound difference. If sound is what you are after, either a full exhaust or cat-back is a better bet.
  4. #24
    Jun 2007
    What about back pressure? What have you noticed? For instance, have you gained more mid-range and more up-top but lost a bit down low?
    PS be great if you could post some photos of the mod if possible.
  5. #25
    Nov 2006
    Neil, Can't answer the back pressure one, and I think I'll need to get the full data set to answer where the power is accurately, but if you revisit the charts (esp. the Mainline ones)....this may send you cross-eyed ..., you can see that while the curves are very similar, the run with the dump pipe gains its power more rapidly that just the tune run.
    It's all over by about 5,300 but the dump makes the progression seem much more linear -- the REVO tune delivers significant surge from 2,500 relative to stock, which you really feel; the dump smooths this a bit but nothing is lost down low. In fact, looking at the torque curve, which peaks at almost 300Nm at 3700rpm, it's above 200Nm all the way from around 2000 until 6. And that's what you feel (and what keeps breaking traction).
    I'll try to get a photo this weekend
  6. #26
    Mar 2007
    Melbourne, VIC
    I don't even know what a dump pipe is but it sounds like an impressive mod. With limited car technical knowledge I'd probably find it easier to go for the full APR system, but since that's ~4 times more expensive I'd probably not...
  7. #27
    Jun 2007
    Brunswick, Victoria
    Yeh I definately dont want any change in sound just improved performance.
  8. #28
    Oct 2006
    Funk
    Dump pipe is the name for the exhaust pipe from the turbo to the cat(Catalytic converter). It increases the flow of the exhaust gases to the cat.
    Cat-back is from the cat to the tip of the muffler.
  9. #29
    Nov 2006
    I have a 3" dump and high flow cat on my car and it does make a different noise.
    Turbo spool is slightly louder and has a rougher sound to it (spooling) - Even friends of mine had noticed it.
    I found it gives a noticeable increase in midrange (where the turbo is on strongest) and slows the dropoff up top. No real difference to low end power.
  10. #30
    Dec 2006
    Gold Coast
    Quote Originally Posted by SoVeReIgN View Post
    Do you like the new noise?
