Results 1 to 8 of 8
Thread: Advise needed
    Aug 2008
    Advise needed
    Hi All,
    I need some advise. Last night I disconnected my battery to do some wiring work on my Polo (will post pics up for this later). Once I reconnected my battery everything is working fine apart from the auto up/down for my windows. If you hold the button the windows work but not the auto function. Is this a possible blown fuse or something that would need to be reprogrammed with vag-com? If it's a vag-com thing is there anyone in Sydney that can look at it for me (don't really want to go back to the dealer).
    Cheers,
    John
    To reset the power windows by lowering the driver’s side window all the way down and holding the switch for about 10 seconds and see if that works
    2013 4Motion "BLACK BEAR"
    http://blackbeartiguan.blogspot.hk//
    Aug 2008
    Thanks for that. I'll give it a go later on and see if that works.
    Cheers,
    John
    Aug 2008
    That did the trick. Thanks for that.
    Cheers,
    John
    Jan 2009
    sunshine coast
    awsome , sooner or later ill replace the stock battery, ill keep that as a mental note i think.
    not at all~
    Sep 2008
    Perth, Roleystone
    There is also a reference in the manual about fixing the window's aswell. Not sure what page tho.
    BMW E36 M3 3.0L LTW - SZYBKI
    VW Up! 1.0L - WGN WERKS
    Nov 2008
    Killara Sydney
    Window initialisation
    Quote Originally Posted by JCM308 View Post
    Hi All,
    Hold window switch down until bottoms and hold for 5 secs then all the way up and hold for 5 secs, do the same for pasengers side. There will also be codes logged for voltage lost in several ECU's but you won't notice anything.
    Joe Chu
