Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Adjustable Strut Tops
    Nov 2006
    Georges Hall
    Another little problem is if you have adjustable front shocks that adjust at the top.Because of the different construction of the adjustable top mount,the top of the shock is 20mm or so lower in the tower.The adjuster on the Konis I have was nearly flush with the hole in the tower.With the new mounts my adjuster wouldn't reach far enough into the hole,so we made up a new one.
    Not a problem with non adjustable shocks but something to be aware of.
    vanilla5 Guest
    i run coilovers so shouldn't be a problem
