For road use the standard setting of 20mm would be best on a Polo as you describe.Stiffer settings really only applicable to GTI's with track use.
Len
Hi
For an otherwise stock tdi polo, which setting of a 20mm whiteline adjustable sway bar would be recommended?
would it be likely that the car would start handling unpredictably in wet weather if it went up to 'hard', say? or is a 20mm bar not likely to make that much of a difference? certainly on 'soft' it makes for a huge improvement compared to no bar at all (stock).
Len
would the rear tend to slide out even on the medium setting on liftoff mid-corner?
alright, that's enough for me - girlfriend has to be able to drive the car without me going mad with worry for her safety. thanks guys
