Search for "cam pulley" on the group.
Basically was much of muchness. I'd probably go cat anyway.
08 9n3 Polo GTI
Mods: heaps
The ECU does watch though, I think to monitor the VVT. On my other engine I was getting " inlet cam not retarded in time" or something like that errors which was probably the VVT system needing an overhaul. The only way it could know that is by comparing the inlet cams pulse/position (exhaust not monitored) versus the cranks? So if its new zero position is say 2 degrees advanced then it stands to reason that it might not reach retard setpoints in time and maybe generate that same code? Possible but I really don't know
It depends on how the ECU interrelates the triggers for the camshaft angles (inlet + exhaust) compared to the crankshaft angle. i'm no VW ECU expert but most tolerate a couple of degrees variation to allow for chain/belt, guide and tensioner wear. Keeping in mind that 1 camshaft degree = 2 crankshaft degrees.
Gary
If it was an issue you could theoretically offset key the cam pulse wheel back to the standard position? I assume that the independent cam conversion shown earlier has some way to deal with that.
if it's worth doing, I'm sure it's a case of solving the problem if it arises - looks like the cam sensor is just 4 slots in a pressed steel bucket. It's probably on its own keyway
yeah it us from memory.
Anyway price up the cat cams gear and let us know. Ive probably got a timing belt to do at some point and i like wasting my money on things i dont need, this fits the bill perfectly
