View Poll Results: How far should I go?
Voters
8. You may not vote on this poll
  • Fix the gears
    3 37.50%
  • Fix the gears + LSD
    0 0%
  • Fix the gears + LSD + Clutch Upgrade
    2 25.00%
  • Fix the gears + LSD + Clutch Upgrade + flywheel (SM/DM)
    4 50.00%
Multiple Choice Poll.
Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Addressing my gearbox
  1. #21
    Oct 2010
    Melbourne, VIC
    That's why I didn't vote - your intentions alter which option is preferable.
    But really good to hear you intend to improve its handling rather than just run slammed.
    Resident grumpy old fart
  2. #22
    Eltham, Victoria
    Quote Originally Posted by Stuwey View Post
    Did you notice any 'bad' drivability errors in my car when you drive it?
    Fix box. LWFW and clutch. Fit Quaife ATB.
    Have (immense) fun.
    Driving your car made me want to fix mine Stu, I loved it (It felt so much newer!)
  3. #23
    Jan 2009
    blankedy
    I found being too low up front made the ride a bit rubbish.
    In the back, low is fine, I rub over speed bumps, with passengers, on dips at speed, but its fine.
    Good tyres up front for traction, good servicing (recently done engine torque mount, spark plugs, turbo bolts and gasket), which most places would not do / know to look for by default.
    Is your boost / tune not right?
  4. #24
    Jun 2007
    Eastern Suburbs Melbourne
    Lower it further ryan.
    Don't be soft.
    i like volkswagens
  5. #25
    Oct 2010
    Melbourne, VIC
    He said he wants to be able to go around corners rather than just point and squirt
    By the way Ben, according to one of the links that I posted in this thread, dropping the rear of a torsion beam rear end makes it grip better so you end up with more understeer.
  6. #26
    Jul 2007
    Auckland, NZ
    did you decide what you would like to do?
    my gears are little noisy too which is annoying - just at light throttle at around 2000-2500rpm with 3rd / 4th gear. I heard it may be the bearings. It sounds fine on more throttle and shifts fine.
    What's yours like?
    06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
    06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
  7. #27
    Eltham, Victoria
    Thinking I'll replace first and third and swap a tdi 5th in
  8. #28
    Feb 2007
    Brisvegas
    Quote Originally Posted by Bflat View Post
    Like ^^
    Anyone found a longer direct replacement for 1st yet??
  9. #29
    Jul 2007
    Auckland, NZ
    Re: Addressing my gearbox
    Looking forward to your feedback with the mods!
    Sent from my GT-I9305 using Tapatalk 2
