That's why I didn't vote - your intentions alter which option is preferable.
But really good to hear you intend to improve its handling rather than just run slammed.
Resident grumpy old fart
I found being too low up front made the ride a bit rubbish.
In the back, low is fine, I rub over speed bumps, with passengers, on dips at speed, but its fine.
Good tyres up front for traction, good servicing (recently done engine torque mount, spark plugs, turbo bolts and gasket), which most places would not do / know to look for by default.
Is your boost / tune not right?
Lower it further ryan.
Don't be soft.
He said he wants to be able to go around corners rather than just point and squirt
By the way Ben, according to one of the links that I posted in this thread, dropping the rear of a torsion beam rear end makes it grip better so you end up with more understeer.
did you decide what you would like to do?
my gears are little noisy too which is annoying - just at light throttle at around 2000-2500rpm with 3rd / 4th gear. I heard it may be the bearings. It sounds fine on more throttle and shifts fine.
What's yours like?
06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
Looking forward to your feedback with the mods!
Sent from my GT-I9305 using Tapatalk 2
