![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
Bflat
I plan on ditching the stance it's currently exhibiting for a more practical and 'fun' height so as to utilise the power available at all times (other than just point and shoot as it happens at the moment).
That's very good to hear.
I'd decide how far I'd want to go power-wise before sorting out the box. If not too far, then fix the box and nothing else. If you're going to go big turbo, then go the 02M conversion (it does weigh about 25kg more), a stronger clutch (light FW if you don't mind chatter) and a TBD or Salisbury LSD.
Resident grumpy old fart
