Results 11 to 20 of 23
Thread: accuracy of our speedo
    Feb 2007
    SE Qld
    Quote Originally Posted by anarchycamp View Post
    yep all new VWs have this "feature"
    There are some other threads on this forum that mention the same thing. It may have something to do with the speedo not being linear (10k increments up to 100, 20k above that)?
    Also, for those with Climate-Control, there are some other threads here that describe how to access the internal data via the Climate-Control panel (shows up where the cabin temp display normally is). This correlates well with my TomTom (which is what I use instead of the speedo).
    Its strange however that the over-speed alert on the dash correlates with the speedo position instead of the digital data via the Climate-Control.
    Mar 2007
    Melbourne, VIC
    Quote Originally Posted by dilbert
    Is in fact 10k increments up to 80, 20k above that!
    Completely useless... I drive through the Melbourne Citylink tunnel every day and it's got a fair few speed cameras. Limit is 80, and with the increment happening then and with the 10% issue, the speedo makes it near impossible to decipher what I'm actually doing. They really should have made the swap at 130 and upwards.
    Not to mention that I also am using polarised prescription Ray Ban sunnies (fantastic stuff to eliminate glare!) whilst driving @ day time. In the darkness of the tunnel, and with my sunnies, the blue lighting makes reading the actual speedo just about completely illegible.
    No such issues in my Accord Euro which features much bigger dial, bright and clear types, with no funny scale swaps until getting into the serious end of the speedometer scale.
    Sorry to sound like a broken record, but it's quite a bit weird user interface wise because conversely the Polo's mirrors are the best I've seen - with the convex design virtually eliminating the blind spot. My Euro's are severely limited here, in comparison.
    EDIT: Speedos are out of focus, but these two shots really show off the difference nevertheless. I.e. you can almost work out the numbers of the Euro, whereas in the Polo it's just a blur.
    Jun 2007
    Quote Originally Posted by Funkdancer View Post
    On the Jetta the change in increments occurs at 100 KM/H, I find it very confusing, when I should be concentrating on where I'm going I find myself having to look closely at the speedo.
    George
    06 Jetta 2.0TFSI Killed by a Lexus!
    09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
    14 EOS 2.0 TSI has arrived!
    Mar 2007
    Quote Originally Posted by VW Convert View Post
    George
    One word, George ... Glasses.
    Dave
    Jun 2007
    Quote Originally Posted by DaveMack View Post
    Dave
    Clever Dave, clever!
    George
    Jun 2008
    i went for a long cruise yesterday on he Freeway, 400km both ways. set the cruise control to 100kph, but according to TOMTOM my actual speed is 92kph.(I even asked my mate, who was driving in front of me set his cruise on 100kph as well, his car the golf gti, STOCK)
    Did 120kph on the speedo, but on Tomtom only 109kph.
    So i tried low speed, 60kph on speedo, 57kph on tomtom.
    is this normal on the gti? I've got this car brand new 2 weeks ago. everything is stock.
    Jan 2008
    Sep 2008
    North QLD
    that would explain why every man and his dog was passing me when i was doing 110kph on the speedo in a 110kph zone.... and i sat on 100kph on the highway and every man and his dog was passing me then too....
    Looks like i need to get a GPS of some sort to get correct indications
    Kuala Lumpur
    Any car speedometer will definitely overread, I'd say 8-10%. Using normal GPS (without differential) will not be accurate either because of signal and multipath issues. I've used a industrial spec GPS with Omnistar real time differential to test this issue, you'll see difference from 80km/h onwards
    Jan 2008
    Quote Originally Posted by Small_Fryz View Post
    GPS costs more than getting your speedo recalibrated. But recalibrating the speedo doesn't tell you where to go.
    Quote Originally Posted by firdausasri View Post
    I've had mine tested on a dyno. Wrong by around 5% all the way to 160. I've got 17s on mine so it's been corrected a bit.
