Results 1 to 2 of 2
Thread: ABS, EPS lights on scan shows codes 01201 / 00301 - Brisbane
    Hi All
    Polo GTI MY07 about 115km on the clock and the other day just all of a sudden after turning car on got the red warning light, ABS light and EPS light all come on
    Took it to my local and they scanned it and got back the following codes:
    01201 - ABS valve supply voltage low
    00301 - ABS return flow pump (V3a) implausible signal
    So they did a few checks, make sure no metal or rocks caught in sensors, flushed the brake fluid etc but couldn't tell what the issue is. So he recommends take it to an auto electrician or to VW to see what's wrong.
    Can anyone recommend anyone in Brisbane the best place to go. It has cost me $90 for the scan just to find out what's wrong and if it turns out the ABS module is stuffed I heard that can be anywhere from $800 - $2000 to replace depending on where you go to.. Also I've read other posts where it's just been issue with a fuse or wiring and again I don't want to get ripped if that's the only problem..
    Anyway if anyone can recommend that be great. Would you think only after 115000 KM the ABS module could go? Cheers
    Quote Originally Posted by clone_tk422 View Post
    Hi All
    00301 - Ross-Tech Wiki
    Post #10 01201 ABS Pump Voltage Supply - help required - SEAT Cupra.net - SEAT Forum
