Results 1 to 10 of 14
Thread: ABS brake pump FAIL
    ABS brake pump FAIL
    Hi, an ABS warning light (amber, not red) came up on the dash and brought my Polo to a K-mart mechanic who did a diagnostic (the nearest mechanic at the time). The computer said "code found:01276 ABS HYDRAULIC PUMP-V64". The mechanic told me that it could be the ABS fluid pump which is faulty but could not identify the real issue. The price for a new pump is $2,000 (just for the part) !! Anyway, I got charged $92 for the diagnostic and does not have a real answer about what is wrong. The mechanic told me that it could be just the controller of the pump or even a wiring problem...
    Has anyone had the same issue? What should I do?
    Thanks for your help,
    Polo 5 Doors 2003 MATCH
    Manual
    85,000 Kms
    Feb 2008
    Go to a dealer, and get it looked at. If the car is under warranty, you should be able to get it sorted for free.
    May 2007
    West Ryde, NSW
    Seeing as your car is 2003, looks like it is out of warranty.
    I would avoid Kmart and would go to an independent VW / AUDI specialist if I were you. Derek at European Autotech (Mona Vale), Seb at EuroAutomotive (Girraween) and Matt at Camden GTI (Golf Loon on the forum) all come highly recommended - suggest looking at recommended repairers and parts suppliers for their details.
    NickZ
    Former ride: MY07 Black Polo GTI
    Current: MY09 Blue Passat R36 Wagon
    Go and check with your ABS fuse
    2013 4Motion "BLACK BEAR"
    http://blackbeartiguan.blogspot.hk//
    Jun 2008
    ... but was it EPIC?
    Aug 2007
    Just because an item is flagged on the code doesnt mean its the unit, the description given is very vague. ABS pump then what??? implausible signal, low voltage , resistance,?????? more description reqd so like some have mentioned avoid K mart
    Jmac
    Alba European
    ABS brake pump FAIL
    Thanks everyone. Indeed, my car is out of warranty. In case it's the ABS pump, would you replace it with a 2nd hand pump from the wrecker?
    Quote Originally Posted by vwlovr View Post
    Get it diagnosed before mentally spending money on it. like Jmac said you can't go from what Kmart told you, they are a supermarket not VW specialist.
    How much do you think it would cost me to get a specialist to find out the problem? I am thinking of going to EuroAutomotive (Girraween) ?
    You want to know how much to scan the ABS first. Then go from there. I would expect them to do that for $50 or less tbh.
    After that they'll be able to give you estimates of what it is likely to cost to fix.
