Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: 9N3 GTI Rear Axle Bushes
    Eltham, Victoria
    Quote Originally Posted by firdausasri View Post
    Hi Guys,
    I would like to update to you guys that ECS Rear Axle Bushing Kit for Mk4 Golf GTI does fit into our 9N3 like a charm
    How's the difference? Pro's/Con's?
    Kuala Lumpur
    I did this to sort out the existing worn out bushing which squeaks like rats. In terms of performance, it does in a way tightens up the rear end a little bit making every turns more responsive. Downside, it's PU and without regular lubrication, it will squeaks and labour cost as you need to bring down the whole trailing beam to install and pump the new ones.
    Oct 2010
    Melbourne, VIC
    That's good information as we now know that mk4 golf rear bushes (and more importantly, compatible cupra rear bushes) will fit our polos
    Resident grumpy old fart
