Results 1 to 8 of 8
Thread: 9N3 GTi Power/Engine Cutoff
    Dec 2012
    Perth, WA
    Hi all,
    Just want to share my experience. I have a 07 9N3 GTi and last week the car started to stall / cutout for no reason. It would happen while I am pulling away from the lights, or even while in neutral waiting for a set of lights.
    In the last few occurrence, I would lose my clock/trip computer settings, and my radio went into "SAFE" mode.
    Called the RAC battery guy thinking it's battery related, but the battery charge level and alternator charge level came back OK. He plug in his OBD computer and came back as "engine stalled", and he suggested probably due to clogged fuel filter due to bad fuel quality in WA, although I only pump RON98 from Shell or Caltex. I thought that was not logical as it would not explain the clock/trip/radio reset.
    I've sent it in to VW Osborne Park and they have come back saying that the battery cable is "shorted" - whatever that means. It has to be replaced and waiting for parts to fly in from eastern states. The car is no longer safe to drive until the replacement battery cable is put in.
    It's just my luck that this happened when VW is at it's most busy. I'll update on how it goes.
    Quote Originally Posted by Johnliew View Post
    Hi all,
    Sounds like something has rubbed through the battery lead, maybe to the starter motor? Shorting it to earth and dragging all the power down with it?
    Dec 2012
    Perth, WA
    I did take a quick look at the battery leads before sending it in, (so did the RAC guy) and could not spot anything obvious. Could it be from the bunch of wires (around 5 I think) connecting to the positive lead via a small box?
    Could be something in there melted through, wouldn't be too unusual.
    Aug 2007
    Perth WA
    There's a small secondary fuse box on top of the battery so it could be something shorting in there as Gav said rather than the main line. Hope you get it sorted quickly mate
    '04 BMP MkIV R32 #144
    search getnew
    Dec 2012
    Perth, WA
    Quote Originally Posted by geoff_gti View Post
    Thanks mate, I hope so too. Still no news from them, and my car is sitting in the workshop...
    Dec 2012
    Perth, WA
    Hey all,
    Just a quick update, the car is now back from the shops and problem fixed. It was the "battery cable harness" - whatever that is. Lucky I had AutoAssure Advantage extended warranty, all labor fees and parts were waived.
    Jan 2009
    blankedy
    Good news! Thanks for the update
