Results 1 to 10 of 11
Thread: 9N3 GTi front hubs vs 6R GTi and TDi
    Oct 2010
    Melbourne, VIC
    Does anyone know if these parts are interchangeable between these cars?
    AFAIK, they all run the same brakes
    Resident grumpy old fart
    Oct 2010
    Melbourne, VIC
    Never mind. My mechanic was able to get a replacement
    Now to check if I should get an MCA kit or the Bilstein repaired
    Quote Originally Posted by kaanage View Post
    MCA seeing as I paid for all the development on my kit..... Free camber top mounts.
    Oct 2010
    Melbourne, VIC
    I'm contacting them now, regarding suitable spring rates
    Nov 2012
    WA
    I'm prob going to jump on MCA as well, just waiting for the right time to break it to the missus
    08 9n3 Polo GTI
    Mods: heaps
    Oct 2010
    Melbourne, VIC
    Since I broke my car, including the passenger strut (and hub, of course), that's half the job taken care of!
    What the hell did you do to it???
    Cheap, Fast, Reliable. Choose two.
    Oct 2010
    Melbourne, VIC
    I thought I had posted about it in the "What did you do Today?" thread but obviously not
    I just clipped the outside kerb at a roundabout entry (I was watching an oncoming car to make sure it wasn't going to turn across me so I turned in a touch early). Sadly for my PoD, the kerb, at that point had a small chunk missing (about 15cm wide) and because only the edge of the tyre went into the gap, the sidewall was pinched and the edge of the rim hammered into the kerb, resulting in
    1. Totalled tyre (massive hole torn in sidewall)
    2. Possibly totalled rim (big chunk out of lip and possibly buckled/cracked)
    3. Bent hub
    4. Bent strut at base
    Jan 2015
    New Zealand
    That sucks Roundabouts plus sorted Polo usually equal fun, not torture.
    Nov 2012
    Let us know if you join the club.
