Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: New Front Bushes for my Gti - who to install them in Sydney
    Jan 2013
    Gold Coast Qld
    I recently bought a nice 07 GTi , my mechanic went through it and said the front bushes were all worn,
    Through my research here I have now got a set of Whitelines to install , but the car is now in Sydney for 6 months. I'm working near Moore Park,
    Can anyone here recommend a good reliable person to change the bushes
    Much appreciated
    Watto
    Erskineville, NSW
    VW Village at Kensington or Wolfsburg Motors at St.Peters
    Oct 2010
    Melbourne, VIC
    vwthunder told me that he just undid the bolt running through the bush, chopped out the old bush and pushed in the Whiteline one (possible with polyureathane bushes but not with rubber). I expect he had the front end up on stands
    Resident grumpy old fart
    Jan 2013
    Gold Coast Qld
    thanks guys, normally I'd give it a go myself kaanage up on the Goldy, but I don't have the means, I use to go to Andrew Dodd @ North Rocks in my Aircooled days , I guess I should offer him first go .......
    I know the guys at Wolfsburg, If Andrew doesn't want the job, I'll get them to,
    Thanks guys
    Watto
    Jan 2013
    Gold Coast Qld
    Thanks guys, I ended up going to VW Village, great service, and the Whitelines are great . next suspension mod ???? sway bars front and rear ???
    Erskineville, NSW
    You probably would have been better off to fit the alloy lower control arms with anti-lift kit.
    What tyres are you running? How many km has the vehicle done.
    If it's up above 60,000km then some quality dampers would be the best improvement.
    If the dampers are fresh then some quality tyres.
    You probably would have been better off to fit the alloy lower control arms with anti-lift kit..
    Not seen any for the Polo?? There is caster correcting bushes though which make a big difference to the handling.
    gavin
    Feb 2007
    Brisvegas
    Yeah Superpro went cold on my request to make them for the Polo.
    And front and rear sway bars FTW!
    Jan 2009
    blankedy
    Coilovers with a rear sway IMO.
    Weitec for and whiteline for a good cheap solution.
    I have the stiffer front bar, does help, but comfort suffers.
    More poke, better tyres for the front end and you're on the right path.
    Melbourne, Vic
    Got the Superpro lower control arm bushes, massive improvement in handling however higher cabin noise and vibration.. Still worth it!
    Rear sway bar will probably give you the best bang for buck improvement after the control arms
    2016 Golf R, APR Stage 1
    2010 Polo GTI 9n3, 4 Program APR Tune, PD160, White line front and rear sway bar
