Can anyone tell me what the minimum front rotor (256mm Diam) thicknes is on a 2003 Polo? I have measured the front rotors and they are 20.1mm/20.4mm in thickness at 53,000kms. I can't find a minimum thickness stamped on the rotor itself, unless its on the inside face?
Also what are poeple using as OEM replacements? I have done a search through the forum and brands like DBA, RDA and Zimmermann come up. Are there any other rotors worth considering? I'm just after normal street use rotors with good braking and improved logetivity (ie last a few pad changes).
If anyone can point me to good/well priced 256mm Diam front rotors that'd be appreciated.
As for pads I already have quotes for Bosch (Quick Stop) @ $64, Lucas @$110 and Bandix GTC @ $120 a set. From the forum it looks like the Lucas pads are a good buy.
