Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: '97 Polo Starter Motor
    Aug 2007
    Ah well they are not too bad to do.
    Alba European
    Nov 2005
    Sydney NSW
    Quote Originally Posted by Bug_racer View Post
    If its auto they are a pain to fit !
    Yep... I did my Mums Starter 2 months ago!
    In an Auto Polo (6n) the Starter is found between the engine and firewall about halfway up the engine.
    Stick your car on Ramps and get under it.
    You will be under it for a while so put down some cardboard or a old blanket.
    You can do it but you will be flying a bit blind and have you use your spidey feelling snece to undo/redo up the bolts.
    (from memory) 3 bolts, 13mm and you have to use combination of ring spanner, sockets with long+short extensions just to get the handle in a space so you can use it.
    The Biggest pain was undoing the electrical clip. As you hands are in an awkward position to squeese and pull.
    Best to do this while the car is not hot or warm.
    You will touching engine bits.
    \( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
    ((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
    Aug 2007
    Yeah with the hot engine you will leave half your hand in there hehehe.
    Jmac
    Alba European
