![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
Buller_Scott
to be honest, when gtidave had his little rascal (pog gti, worked well), i was surprised - he would cruise in higher gears than myself for in-and-around-town duties.
You need to get serious and start shifting at 1200rpm and cruising from 50km/h onwards in 5th, Scotty. The Pod will easily do this on flat roads. Of course, with the SuperPro torque arm bush, it might give a pretty serious massage ![Wink](https://www.vwwatercooled.com.au/forums/images/smilies/icon_wink.gif)
Buller_Scott
do you guys have a vent function? a little button on the inside of the fuel mouth?
Yep. flat6 certainly knows as he gets 10-15 extra litres (I get 10.75 more). I used about 57 litres before chickening out and filling with my last tank.
The stupid MkVI Golf can't be vented so the Polo can actually hold more fuel than the Golf
Resident grumpy old fart
