I'll be going for the strenghend 5 speed syncro set with taller ratios from sqs![]()
I wish they could do a dog box conversion along with that(plus I'd like the taller 1st and 2nd they offer for the TDi version but would like to keep 3rd, 4th & 5th as is - see the spreadsheet http://www.sqsracing.com/produkt/276...ng-competition)
Resident grumpy old fart
Thanks for the great links everyone. I knew there was something out there, I'll look into it a bit more - would be great to have that extra gear for all the highway driving.
Are there different gearbox options/codes for the 2006 9N 1.8 Polo GTi? If so, where do I look to find what code mine is?
Cheers,
Scott
Red 2006 Polo GTi : Forge Splitter - TIP - ITB - Forge Front & Rear Strut Bars - Dash Cubby - Fumoto Valve - Full Milltek Exhaust - PD160 Intake - K&N Panel - ECS Stage 1 Clutch - Seat RCA Bushes - APR Stage 1+
