Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: 60km/h - Are you in 4th or 5th?
  1. #21
    Feb 2008
    4th for me...just easier that way.
  2. #22
    May 2007
    West Ryde, NSW
    Get in the car and drive on a straight road with a constant incline. Set the trip computer to show the current fuel consumption, and then try cruising on 4th and 5th.
    Especially on an incline, you will find 4th is actually more efficient than 5th gear, you have to put the pedal down more to maintain the speed as the car is out of its peak torque, and hence using more fuel. But this is not really important, the bad part about this is that, as said before, labouring your engine at low revs is going to cause you problems in the long run.
    In saying that, I cruise at 65 - 70km/h in 5th, but if i need to accelerate or am going up a hill and finding i am doing any more than just touching the throttle, i drop it to 3rd or 4th and keep the revs above 2000.
    NickZ
    Former ride: MY07 Black Polo GTI
    Current: MY09 Blue Passat R36 Wagon
  3. #23
    Mar 2007
    VIC
    How many revs should we be doing in cruising in any gear? And how low can we go before we shift down?
  4. #24
    Jun 2008
    Sydney, NSW, Australia
    Quote Originally Posted by poloplayer View Post
    My general rule, for cruising in any car, petrol or diesel, is...
    5-sp manual-
    40 & 50km/h = 3rd
    60 & 70km/h = 4th
    80+ = 5th
    6-sp manual-
    40 & 50km/h = 3rd
    60 & 70km/h = 4th
    80 & 90km/h = 5th
    100 & 110km/h = 6th
    This sort of driving has netted me some pretty decent fuel results in everything I've owned, so I'm not about to stop.
    2008 Volkswagen Polo 1.9 TDI
  5. #25
    Apr 2008
    Perth
    see i prefer
    1st 0-60
    2nd 60-100
    so on and so forth
  6. #26
    Jan 2008
    Cremorne, Melbourne
    Quote Originally Posted by PoloGTIBoy View Post
    see i prefer
    1st 0-60
    2nd 60-100
    so on and so forth
    thats the spirit!
    2010 Reflex Silver MK6 Golf GTI
    Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
  7. #27
    Canberra
    My experience has been that if the road is flat, you'll get better fuel economy from 5th gear than 4th at 60km/h. Driving from Palmerston in ACT to the airport at 5am I regularly average 6.1-6.2l/100kms, it's all fairly flat and most is done in 5th. I did this in 4th, it was more like 7l/100km.
    Sure, if you need to put your foot down change to 4th (or 3rd). Otherwise 5th is just fine at 60.
    You may also notice that when you slow down to a stop, if you coast (in neutral, i.e. not in gear), you are using more fuel than you would if you leave it in gear for as long as you can. I've never really understood why but it's true. All these things help for better fuel economy if that's what you're after.
  8. #28
    Jan 2008
    Cremorne, Melbourne
    Quote Originally Posted by ACTGTI View Post
    which brings us straight back to this post........
    Just because the engine is making boost doesn't mean that it will use more fuel.. Boost should make the engine more efficient and therefore you would be able to use less throttle. ie, there should be no difference.
    One thing you guys are forgetting is that labouring an engine like that (1500rpm in 5th..) is worse for it in a lot of cases than revving the snot out of it. Lower oil pressure, more blow by, it can fracture rods/pistons etc etc.
    My advice would be to leave it in 4th. The difference in fuel economy would be VERY minimal, if at all noticable.
  9. #29
    Alfred Cove, WA
    I usually do 63km/h in 5th (i know the speedo is out), but if I need to go up a hill its either 4th or 3rd. If I still lived in Brisbane there is no way I'd do 60 in 5th because it is slightly hilly to very hilly everywhere. But the northern and western sides of Melbourne is flatter than a 10 yr old.. errr... well flat.
    I agree labouring an engine is bad, but if it is perfectly flat or even slightly downhill I don't consider that labour.
  10. #30
    Canberra
    Quote Originally Posted by Ben_GTI View Post
    I agree, I don't consider cruising at 60km/h in 5th on a flat bit of road labouring the engine.
    The engine is not under labour just because it's revving at 1500rpm in 5th, it's only labouring at the point where you put your foot down at 1500rpm in 5th which I don't do.
