60k is plugs ( longlife) or if you are tuned then you will fit colder ones more regular, air filter, pollen filter, fuel filter , oil filter, sump plug and oil. Brake fluid is every 24mnths unless running stuff like GS610 Martini then its 12mnths, so i dont guess as a lot of service history goes of track, cant go wrong by doing a moisture test on the fluid, any more than 2% moisture change it.
If you have went 5 yrs and you are 60 then its a cam belt too. Not throwing a spanner in the works but dont forget the cam belt is every 5 yrs on the BJX or 105kss
Jmac
Alba European
06 Polo GTI
standard ECU, wheels | K&N Panel filter | PD160 intake tube and trumpet |Nulon 5W-30 | Michelin contact sport 3
