Results 11 to 20 of 39
Thread: 42dd shifter cable bushings
    Jul 2007
    Auckland, NZ
    sounds like the biggest difference is by Verdict motor bushings.
    06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
    06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
    Jun 2009
    PJ/Selangor, Malaysia
    Quote Originally Posted by jesum View Post
    i had mine put in 2 days ago and i can definitely feel a difference. if you do normal driving, it won't feel very different but try quick flicks / gear changes and you will see that they slot in a lot more accurately than before especially from 1st to 2nd. there is less hesitation as a result.
    btw, i have also changed the pendulum mount bushing so that might make a difference too.
    oops! my apologies. silly me, i should clarify that i put in the verdict motorsports bushings and not the front/side endlink bushings from 42dd. sorry.
    Aug 2009
    West Footscray, VIC
    Actually, i've had any few tries, 1st to 2nd to 3rd, it did seem abit more percise (Verdict Bushings).
    I think the 42DD ones for the endlink will make a greater difference as it's a more direct part of shifting. I'm def getting one of those
    Black|APR Tuned|APR Dogbone|SEAT Intake|BMC Airfilter|Forge TIP|SEATSports Front Strutbrace|Forge Rear Strutbrace|Whiteline RSB|Bilstein B8 & H&R Springs
    Feb 2008
    Camden
    Quote Originally Posted by jasonc23 View Post
    I purchased a set of these 42 Draft Designs shifter bushings and managed to fit the front/back endlink without any trouble. Shift feel is pretty awesome combined with the verdict motorsport bushings I have already.
    But I'm having trouble removing the side/side endlink off of the black plastic pin holding it in place. It doesn't have the metal retaining clip like the front/back endlink; instead it's held on by a little raised plastic part on the pin which I've tried to push down with pliers which doesn't work. Can anyone help me?
    EDIT: Never mind guys, didn't read the part on how VW introduced the plastic bracket for the side/side linkage. I need to drill...
    Guys I just installed both the Verdict and the 42dd bushes, and the good news for those installing the 42dd bushes and have an early build (Oct05 - May06) that has the HWY gearbox, you can easily install both the front/back AND the side to side bushes.
    The early HWY gearbox has the advantage that both the end clips are metal and are easily removed.
    Can't say it took me 1/2 an hour to install, both lots of bushes are are relatively easy, but removing the strut brace, intake pipe and air cleaner is such a pain.
    Shift feel is firmer and more precise, though we are talking degrees here. A cheap upgrade and recommended for those who see the track, or like just want better feel.
    Jas.
    Jan 2009
    blankedy
    Oh, I'm not going near my TIP, that was such a pain... Maybe attack from underneath?
    Oct 2009
    you don't need to take out your tip, just the airbox and intake hose
    does it easy to install by myself? just unplug the old one and plug in the new one?
    2013 4Motion "BLACK BEAR"
    http://blackbeartiguan.blogspot.hk//
    Oct 2006
    very easy to install, definitely worthwhile! did it on the mk4 and was brilliant..
    Aug 2009
    Quick Q, can anyone clarify how I remove the lower half of the airbox. Top half is easy enough, but lower half isn't as obvious.
    Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
    Current Ride: Evo 8 MR, Fabia MK3
    Jun 2009
    there is only one screw to undo.
    if you are standing at the front of the car, look at the lower right corner of the airbox. there's a screw around that area (a bit deep). remove that and pull the lower half out.
    the airbox is held in place by 2 things - the screw mentioned above, and a piece of rubber (don't know what else to call it) somewhere around the lower middle section. this rubber is similar to the one that holds the engine cover in place.
