sounds like the biggest difference is by Verdict motor bushings.
06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
Black|APR Tuned|APR Dogbone|SEAT Intake|BMC Airfilter|Forge TIP|SEATSports Front Strutbrace|Forge Rear Strutbrace|Whiteline RSB|Bilstein B8 & H&R Springs
Guys I just installed both the Verdict and the 42dd bushes, and the good news for those installing the 42dd bushes and have an early build (Oct05 - May06) that has the HWY gearbox, you can easily install both the front/back AND the side to side bushes.
The early HWY gearbox has the advantage that both the end clips are metal and are easily removed.
Can't say it took me 1/2 an hour to install, both lots of bushes are are relatively easy, but removing the strut brace, intake pipe and air cleaner is such a pain.
Shift feel is firmer and more precise, though we are talking degrees here. A cheap upgrade and recommended for those who see the track, or like just want better feel.
Jas.
Oh, I'm not going near my TIP, that was such a pain... Maybe attack from underneath?
you don't need to take out your tip, just the airbox and intake hose
does it easy to install by myself? just unplug the old one and plug in the new one?
2013 4Motion "BLACK BEAR"
http://blackbeartiguan.blogspot.hk//
very easy to install, definitely worthwhile! did it on the mk4 and was brilliant..
Quick Q, can anyone clarify how I remove the lower half of the airbox. Top half is easy enough, but lower half isn't as obvious.
Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
Current Ride: Evo 8 MR, Fabia MK3
there is only one screw to undo.
if you are standing at the front of the car, look at the lower right corner of the airbox. there's a screw around that area (a bit deep). remove that and pull the lower half out.
the airbox is held in place by 2 things - the screw mentioned above, and a piece of rubber (don't know what else to call it) somewhere around the lower middle section. this rubber is similar to the one that holds the engine cover in place.
