Hey Louis, I'll grab a set too mate.
Hey Guys, I'm looking at getting a set of gearbox shifter bushes from 42DD and wondering if anyone else is keen for a set or anything else small to split up the postage cost as just one set costs more to post then the set itself. Cost is $35 and the link is listed below if you want to have a look.
VW Shifter Bushing Set - Mk4 5/6S MY02-05
Anyone interested let me know
2006 GTI Polo - Big Turbo Build - Louis19's Build Thread
Mods >1
Would these work in conjunction with a quick shifter kit, or would the later negate the former? Thanks.
I know Gav runs the short shifter kit as well as the 42dd bushes....
OK, well I'm certainly keen if we can work out payment and delivery. I'm in NZ but will be in Melbourne for the week of the 16th of March... Will pop you a PM.
Quite a few us of run these bushes in conjunction with the Forge short shifter. Both make for a tighter shift action but the increase in the directness is not as noticable if you have installed one and then add the other.
I also run Gavin's allow shift mounts which makes the shift action than little more direct, again.
With the DieselGeek short shifter, these bushes aren't applicable
Resident grumpy old fart
Cool, thanks for clearing that up. I'll start with the bushes and swap out the oil in the box and see where we go from there. It's not like the shift on these things is too agricultural. Cheers.
I am running all of course With the Forge big knob. Works well. All l need is a motorsports shifter now
Are you looking to bundle post then repost when they land? Of doing a postage deal with supplier
08 9n3 Polo GTI
Mods: heaps
