Results 11 to 20 of 29
Thread: 4 Year Service Costs
    May 2010
    S.E Melb
    I had my 60k/4 year service (service plus timing belt change) for $1100 on the pog through my local trusted mechanic at 54k's
    Called Werribee VW for a quote and they said $880. I was like oh yeah thats not bad, and then they said $1150 for the timing belt on top !!!!
    MY07 Polo GTi
    Last run - 114.8kw atw
    Winton - 1:52.7130
    Mar 2011
    Camden, NSW
    I've booked my 2006 POG in for a 60K service early next week.
    Campbelltown VW service centre quoted $850-$900, I called repco and confirmed they could do the same job for $420.
    I know where I'm going!
    Adelaide hills, SA
    Quote Originally Posted by Drew View Post
    I would rather go to the independent VW specialist, like Camden GTI
    Mar 2011
    Camden, NSW
    Thanks for the suggestion Transporter
    What would you say the benefits would be? I called Camden GTI up and they couldn't give me an exact quote but said it wouldn't be more than $600 parts and labor. A part of this price included $120 just for 4 Bosch spark plugs.
    Feb 2008
    You have a VW specialist who I know for a fact knows VW's inside out. They have the proper ability to scan and correct the cars diagnostics, and are pretty good blokes too... Take a run down to the workshop and have a look for yourself.
    May 2007
    Burleigh Heads, Qld
    This thread should be closed lest Jimmy read it and get ideas..........
    May 2007
    West Ryde, NSW
    Repco for $420 with all due respect seems too cheap for a major service - did you ask what oil will they use? A proper VW 502 approved or some cheap stuff? Are they going to use the right oil filter and not a Ryco?
    $600 for all parts provided is very reasonable IMO and for the extra $180 you would have peace of mind that your car is being serviced with the right parts by the right people.
    NickZ
    Former ride: MY07 Black Polo GTI
    Current: MY09 Blue Passat R36 Wagon
    Erskineville, NSW
    Drew, i have a Skoda Octavia. I used to get it serviced at the VW dealer in Campbelltown & they quoted the 60,000km for $900+ and after some discussion on what they were actually offering for the money, came down to ~$700-ish.
    I eventually had the 60,000km done at Camden GTI & it was significantly less than $700 but I didn't get spark plugs done. Indeed, the correct Bosch spark plugs are $20-$30 each. I was quite satisfied that CamdenGTI used the correct oil & an OEM spec filter. They also scanned my ECU and found a small issue that needs to be looked at by the dealer (N75 fault).
    Before committing to Repco, I'd ask them:
    • What oil are you using & what VW specification does it comply with? (502.00 at a minimum, 504.00 better still)
    • What brand of oil filter will you use? (It should sound German )
    • What scan will you do on the ECU? A simple ODBC or a VCDS/VagCom (you want the latter).
    Think of your service manual too. A dealer or specialist stamp means a lot more than a firm that services any car that rolls into the workshop.
    Mar 2011
    Camden, NSW
    Hi All,
    Thanks for the replies, I've had a couple of busy weeks and totally missed your responses before going ahead with the service.
    I ended up doing some more research and was happy to continue with Repco.
    I ended up getting Synpower 5w-40 (505.01 from what I can find on the net), and not sure what filter (I plan on doing a change mid service anyway).
    Before I saw your feedback about the spark plugs I ended up pulling out the socket set and checking my spark plug type, I called Repco and they were able to fit the exact NGK type that came with the car. The Repco mechanic seemed like a switched on guy, He's an ex-Jaguar mechanic.
    From what I can see, the things I may have missed were an ECU check, and a brake fluid bleed (Camden GTI said they do this, while the Repco mechanic said they do it on a per-need basis).
    I think next service I'll give Camden GTI a call, it'd be interesting to meet some other enthusiasts and potentially get my ECU scanned.
    Having said that - I had a random coincidence where my Tyre pressure warning light came on within an hour after the service. I took it back to Repco and they plugged their diagnostic computer in, they couldn't find any errors and all I needed to do was press the reset button in the middle of the dash!! It's funny as the mechanic said my POG didn't even have tyre pressure sensors. I guess the warning lamp is on some sort of timer that just happened to go off within such a short time after the service!
    Erskineville, NSW
    Press what button in the middle of the dash? (a photo would be good)
