I've booked my 2006 POG in for a 60K service early next week.
Campbelltown VW service centre quoted $850-$900, I called repco and confirmed they could do the same job for $420.
I know where I'm going!
I had my 60k/4 year service (service plus timing belt change) for $1100 on the pog through my local trusted mechanic at 54k's
Called Werribee VW for a quote and they said $880. I was like oh yeah thats not bad, and then they said $1150 for the timing belt on top!!!!
MY07 Polo GTi
Last run - 114.8kw atw
Winton - 1:52.7130
I would rather go to the independent VW specialist, like Camden GTI
This thread should be closed lest Jimmy read it and get ideas..........
Repco for $420 with all due respect seems too cheap for a major service - did you ask what oil will they use? A proper VW 502 approved or some cheap stuff? Are they going to use the right oil filter and not a Ryco?
$600 for all parts provided is very reasonable IMO and for the extra $180 you would have peace of mind that your car is being serviced with the right parts by the right people.
NickZ
Former ride: MY07 Black Polo GTI
Current: MY09 Blue Passat R36 Wagon
Drew, i have a Skoda Octavia. I used to get it serviced at the VW dealer in Campbelltown & they quoted the 60,000km for $900+ and after some discussion on what they were actually offering for the money, came down to ~$700-ish.
I eventually had the 60,000km done at Camden GTI & it was significantly less than $700 but I didn't get spark plugs done. Indeed, the correct Bosch spark plugs are $20-$30 each. I was quite satisfied that CamdenGTI used the correct oil & an OEM spec filter. They also scanned my ECU and found a small issue that needs to be looked at by the dealer (N75 fault).
Before committing to Repco, I'd ask them:
- What oil are you using & what VW specification does it comply with? (502.00 at a minimum, 504.00 better still)
- What brand of oil filter will you use? (It should sound German
- What scan will you do on the ECU? A simple ODBC or a VCDS/VagCom (you want the latter).
Think of your service manual too. A dealer or specialist stamp means a lot more than a firm that services any car that rolls into the workshop.
Hi All,
Thanks for the replies, I've had a couple of busy weeks and totally missed your responses before going ahead with the service.
I ended up doing some more research and was happy to continue with Repco.
I ended up getting Synpower 5w-40 (505.01 from what I can find on the net), and not sure what filter (I plan on doing a change mid service anyway).
Before I saw your feedback about the spark plugs I ended up pulling out the socket set and checking my spark plug type, I called Repco and they were able to fit the exact NGK type that came with the car. The Repco mechanic seemed like a switched on guy, He's an ex-Jaguar mechanic.
From what I can see, the things I may have missed were an ECU check, and a brake fluid bleed (Camden GTI said they do this, while the Repco mechanic said they do it on a per-need basis).
I think next service I'll give Camden GTI a call, it'd be interesting to meet some other enthusiasts and potentially get my ECU scanned.
Having said that - I had a random coincidence where my Tyre pressure warning light came on within an hour after the service. I took it back to Repco and they plugged their diagnostic computer in, they couldn't find any errors and all I needed to do was press the reset button in the middle of the dash!! It's funny as the mechanic said my POG didn't even have tyre pressure sensors. I guess the warning lamp is on some sort of timer that just happened to go off within such a short time after the service!
Press what button in the middle of the dash? (a photo would be good)
