Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: 4 bar fpr and fuel pump
    Aug 2012
    Sydney NSW
    Quote Originally Posted by spraycanmansam View Post
    From what I've been reading the 440's are getting on a bit and there's more advanced injectors out there that are better suited to multi-valve engines.
    The 386cc injectors seem to have a good rep.
    I ran some numbers and running the 386cc injectors on 4 bar will effectively make them run at 446cc (assuming they are rated 386cc at 3 bar) When the fuel pressure rises with the added boost pressure as you mentioned, they'll effectively be flowing 525cc at ~5.5bar.
    Then using this formula:
    Inj size (lb/hr) x 80% duty cycle / .60 Brake Specific Fuel Consumption
    49.8lb/hr(525cc) x 80% / .60 = 66.4hp per injector x 4 = 265bhp
    So running the TT injectors at 4 bar will support 265 crank horsepower at 22psi if I've done my maths right.
    Which means I'll have to be pushing well over 180kw at the wheels before I need bigger injectors.
    This thread may take out some of the guess work for you :
    VWVortex.com - Fuel injection flow vs HP tables
    More info here:
    VWVortex.com - REFERENCE: Fuel Injectors for 1.8t
    Good links, confirms my maths
    It looks like I'll go with the 386cc, pain in the rear that ECS doesn't have the right ones... I think I'll leave them until I confirm the turbo to be sure.
    Thanks for all the good info.
    Polo GTI MY2008
    Build Thread
    136.09kW and 305.28Nm torques, Dynapack Hub Dyno
    Sam, the ones you need are in the ebay link, part number ends in BC. goggle it see what you find.
    Other wise go with something a touch bigger and run them at 3 BAR.
    Aug 2012
    Sydney NSW
    I got the Bosch green giants. Good reviews :
    Bosch 42lb (Green Giant)
    42lb Green Giant Injector (each) - JH Motorsports Inc. - -- JHM. Shifting you to the next level of
    You can buy them from IE at $50/unit:
    Bosch 42LB / 440cc Green Giant Injector
    Common injector for the power range that you're looking at.
    Sep 2006
    I have the 386cc OEM TT/S3 ones, got them from Preeny.
    They look like the ones on the ECS site, I will see if i can get a part number
    MODS- TOO MANY
    Quote Originally Posted by vwthunder View Post
    Really Troy, I had a set of them and they wouldn't fit in the manifold on my A3. They went in so far they practically touched the other side of the runner.
    Sep 2006
    GIAC specify all OEM
    386cc's
    S3/TT225 MAF
    MODS- TOO MANY
