Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: 312mm Brakes and 16" Wheels.
  1. #21
    Jan 2009
    blankedy
    Quote Originally Posted by nightphotographer View Post
    Could I even go as big as 323mm? I could then get the MK1 Cupra R Brembo Discs which look incredible.
    If you don't need the bigger brakes, you are just adding unsprung weight. The 312mm rotors are not light.
  2. #22
    May 2011
    Albury, NSW
    I don't think it's much to worry about though really. My priorities have always been aesthetics over performance, hence why the car is still untuned. It sounds so lame I know!
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
  3. #23
    Oct 2010
    Sorry if this is too far off-topic, but does anyone know the smallest diameter rims that'll fit over the stock GTI brakes?
  4. #24
    Quote Originally Posted by csimpson View Post
    VR6 Golfs had 288s and came with 15s, don't take it as gospel that any 15 will fit though.
  5. #25
    Oct 2010
    Melbourne, VIC
    Pretty sure that one of the 6R GTi guys (Gambit?) fitted some to his car and they have the same brake setup.
    Resident grumpy old fart
