Gti... Mk5 GTI?
Not the rotor, but the rest of the kit.
As Audi TT is the common upgrade path, I'm assuming there is a reason that Mk5 brakes are not used.
You will need to space the wheel out quite a bit
MODS- TOO MANY
Ahhh that sucks - do you know or can you guess what the minimum offset should be to fit the bigger calipers under? Also Troy - what else do you need to do the conversion?You will need to space the wheel out quite a bit
2019 132TSI Tiguan
2011 Audi S4 Wagon
1988 MK1 Caddy
2006 Polo GTI
Just calipers, carriers, pads, 312mm rotors and spacers, doubt you will find any wheels to cleat it without spacers, even my bora sports which clear R32 brakes needed a 5mm spacer
MODS- TOO MANY
So I don't need any new lines or anything? And what about wear indicator sensors cause the Polo has one right and so do the calipers? Surely that's not plug and play? It's not essential, but would be cool if I cool if I could do that too. So I'll get the calipers, the adapters, 312mm discs, pads and then I just need some spacers.
2019 132TSI Tiguan
2011 Audi S4 Wagon
1988 MK1 Caddy
2006 Polo GTI
Could I even go as big as 323mm? I could then get the MK1 Cupra R Brembo Discs which look incredible.
2019 132TSI Tiguan
2011 Audi S4 Wagon
1988 MK1 Caddy
2006 Polo GTI
Pad sensor is just a contact, you can cut the connector off and join the wires or connect something across the connections. Not really going to cause issues IMO.
