Neil, that doesn't really make sense. AFAIK, Milltek only makes a full system for the Pog (am not sure one has ever been delivered in Australia -- or a DP, if they do in fact do one) and the line about making a bigger pipe only for a bigger turbo is supported more by the desire of marketing people to segment the market (in the same way VAG does) than actual data relating the DP to the stock turbo.
I'm still scratching my head to understand how the primary cat works as a stand-in resonator when it's basically filled with catalyst.
Regardless, my stock exhaust was flow tested before I had a DP built. The biggest restriction in my stock system (which still includes the middle resonator) was the stock turbo to cat pipe. The exhaust tech then explained the maths to me about going to 3" rather than 2.5".
Why go to 3"? Because even a 2.5" will restrict flow at its bends. So, having 2.5" full system from the cat back will still suffer from the bend restriction prior to that, and thus reduces the benefit of the 2.5" system. Wa a a y back, Guy did his initial work on a custom Pog 2.5" exhaust, and found little to be gained. Has this changed?
As far as I am concerned, the proof of the 3" DP is on the table and I'm not sure why people argue against it, without putting forward alternative evidence:duh:
