Results 1 to 10 of 11
Thread: 2nd gear
    Dec 2007
    Essendon
    2nd gear
    Have you guys noticed that when your taking off hard from a standing take-off position, it is pretty hard to put it into second? hmmm I think there was a thread to this topic a while ago? anyone know what im talking about?
    Feb 2008
    I have never had a problem with shifting into second when going hard. By the sounds of other peoples gearbox dramas, I have been pretty lucky...No gearbox issues what so ever.
    Mar 2007
    Same as Blitzen ... but do a search. Most of those with gb problems have symptoms between 1st & 2nd.
    Dave
    Dec 2006
    Gold Coast
    I have no problem from first to second.
    I get 2nd to third
    CRUNCH every second time.
    Jul 2007
    Durban, South Africa
    i have just had my second gear and synchromesh replaced under the warranty - so this is a common problem all around the world on the gti
    i have to now relearn to change from 1st to 2nd smoothly - cos ive been doing a delayed change ie shifting into neutral and waiting for the rev to drop before going into second which was th eonly way i could drive without getting the gears grating and crunching
    but its been fixed sometime last week - so im gonna have to wait a while to see if the symptoms pitch up again
    Jan 2008
    Cremorne, Melbourne
    is this not the 35A7 recall as referred to in the following post: http://www.vwwatercooled.org.au/newf...ht=polo+recall
    a lot of people were having this issue and apparently they change the gearbox fluid from synthetic back to the old mineral stuff. once changed over, it's meant to make a big difference to the gear changes.
    i'm guessing this is what your problem was and that is what they did.
    Cheers,
    Rhys
    2010 Reflex Silver MK6 Golf GTI
    Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
    Mar 2007
    VIC
    Quote Originally Posted by archangel_7 View Post
    Sure do! It feels like i have to force it into 2nd
    Dec 2007
    Essendon
    yeh thats it!
    anyone else experience this?
    Does anyone else use Nulon in their g'box? Be interesting to see if anyone who has broken a gearbox AND has used an additive.
    The box in my 97 Polo makes more noise than my missus when I come home late at night and I haven't been able to get 5th for the last 1000k's. Might just see how far I can push the gearbox before it finally breaks. Hopefully by then I'll have my new GTI.
    Paul
    Feb 2008
    Paul
    If you arn't getting 5th, and your car is that old, you might want to get your shift bushes checked out. If they are plastic, and that old, they may have worn out, and are limiting the amount of travel in your gear selector...I have had it before in a previous car, and I have read about it on other threads on the forum(SEAT Cupra comes to mind straight away). Not too expensive to rectify(about $250 to $450), but it beats a gearbox rebuild straight up!!
