Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: 18's on Polo GTI
    Jun 2007
    Chatswood, Sydney
    lol! screw it just get some multipurpose rubber and wrap it around the rim itd do the same job
    New user account: Mischa
    Have: gt sport tdi, mk2 gti, mk1 3dr
    Sep 2006
    Brisvegas
    Hey Jayzee,
    Mate i think i have heard of someone in the polo section doing it maybe one of the boys OS. But im not sure if you will be able to put anymore rubber on the car as im pretty sure that will rub if you go any wider. Ill try and search some stuff today and put it up for you. Or if you have time do a search and let us know.
    edit - Have a look here mate http://www.vwwatercooled.org.au/newf...ead.php?t=6662
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
    Jun 2007
    Chatswood, Sydney
    my bad, that looks awsome, do it!
    jayzee75 Guest
    thanks for the help guys - will post some photos when the 18's land
    jayzee75 Guest
    there is a guy on this site from durban that has 18's on his polo - 215,35,18 fit withour rubbing
    Jul 2005
    Quote Originally Posted by VWindahouse View Post
    I found this on the BB's Garage site. It seems as though it may depend on the offset of the wheel perhaps. http://www.bb-automobiltechnik.de/bb...B2_polo_9n.php
    For this particular wheel they say it can only fit with 5mm spacers and a 215/35R18 tyre.
    Where as with this link http://www.bb-automobiltechnik.de/bb...B1_polo_9n.php they say you can go as wide as a 225/35R17 tyre and no spacers needed.
    So what are your thoughts is it all to do with offset???
    Just found another tuning company MTM who is selling them http://www.mtm-online.de/en/index.ph...3&FZID=POLO110
    yes... everything to do with wheel offset.... from the look of those wheels the mounting face is really pushed out to the front of the wheel...; so when you mount it most of the wheel will actually sit under the car and possibly interfere with the struts. so if you use a spacer (which i believe are illegal in most states) this pushes the wheel out further and clears the struts.
    golfie_boy Guest
    Exclamation
    hey guys i used to be involved with wheels alot bak home in terms of customising and doing one of things 18`s on a polo do work but offset must be 38 and 7.5jj if not you will need a rather thin alumin spacer as long as the inside just clears the shock you wont really have a problem
