105,000klm service
You'll most likely be doing the timing belt.
Hi Guys,
My car is coming up to it's 100,000 KM service, anyone have any idea how much this costs? It seems to be a big one. I will ring my dealer as well, just want to make sure they aren't going to quote too much.
Thanks
EDIT: 105,000 KM service
2020 VW Golf R
105,000klm service
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Expect $600 - $1000 dependant on who you go for. The timing belt will need to be done. It's all up to dealer vs independents
06 VW 9N3 Polo GTI - Reflex Silver Leather/OEM Colour coded S/guard/OEM Lower Honeycombe Grille/NSP Boost Gauge/APR Stage 1+,Dogbone & DP/K&N filter/Forge s/shift,DV008 & Strut brace/PD 160/Samco camo TIP/Whitline RSB/FK AK's/17 x 8 Oettiger RE's/Alpine Head Unit & Sony Amp. OEM+FTW
VW has quoted me a bit over $1100 for the service including timing belt.
If I wasn't living in buttf... nowhere I could get an independent to do the same for ~ $900 from memory
I suppose since it's a major service i'd rather go VW, I'll ring around today and report back.
2020 VW Golf R
Ok... Just because it's a major service doesn't mean it is outside the ability of an independent. I personally would never go to a VW dealer for any servicing work if I had access to a independent VW specialist.
I can almost certainly guarantee that a VW dealer would charge you a lot more than an independent.
You still have 5,000km before it is due, so a bit of time to ring around...
Any recommendations for independents? I just rang Camberwell and they said it's not due until 120,000KMs.... I know this isn't true because the service book says otherwise.
2020 VW Golf R
Have a look in the Recommended Repaires section of the forum.
And this is exactly why I wouldn't go to a stealership for servicing, they can't even put in the effort to tell you the correct servicing interval.
In no particular order, Volkspower, Volkwerke, Audvolks.
Google them, they're all Melbourne based.
I've got mine coming up in 5,000kms also, and will be doing plenty of ringing around before I book it in.
