Originally Posted by
Zuna
Good day all,
I did a lot of repair work on my polo since my last post. I started by sorting out my starting issue by replacing the tempreture sensor (if i only knew from the start that that was the problem i would have saved heaps!!!), then i replaced my cooling fan motor that burnt out, only getting it right after receiving two fans that was out of balance. The latest was my ignition that gave in so i installed a push to start and oh yeah i did the cvs 3 weeks ago. After we done the cvs i realised that my strut mounts are done! can someone shed some light on this that have been down this road of removing the strut before? Any info will be greatly appreciated!
Hi there... I have done these more times than i care to remember, what would you like to know in particular? given all the work you have done already this should be a piece of cake, there is nothing tricky about them, actually pretty easy compared to the 6r ones. Order yourself a new bearing as well as you may as well change it while you have the strut apart.
if u want to know anything in particular please do let me know
My Car(s): 2011 6R TSI Comfortline (Pepper Silver),
If you're in need of any 6n1 parts, odds are that I am going to have them (dismantling 2 at the moment)
